Sonoff SNZB-02D Unhandled Event PLEASE REPORT TO DEV
I am using the [Zigbee - Sonoff Temperature & Humidity Sensor] driver from oh-lalabs.com
From time to time the following error shows up in the log file. The only way to bring the sensor back to reporting correctly is pressing the sync button a few times and or paring it again.
Unhandled Event PLEASE REPORT TO DEV - description:catchall: 0000 0006 00 00 0040 00 95B1 00 00 0000 00 00 25FDFF040101190000 | msgMap:[raw:catchall: 0000 0006 00 00 0040 00 95B1 00 00 0000 00 00 25FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:95B1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[25, FD, FF, 04, 01, 01, 19, 00, 00]]
Oh-lala labs are no longer active or doing any maintenance or updates of their drivers.
You may want to look for another driver for that device. Searching in this forum for that device would be a start...
Any suggestions? I have tried a few and the sensor never reported back.
The Hubitat inbuilt drivers should be working OK as well.
Thanks @kkossev
