I don't know about the Sonoff SNZB-02B but I recently bought several of the Sonoff SNZB-02LB (Zigbee LCD Smart Thermometer with probe) and when set up with the built in driver (Sonoff Temperature/Humidity Sensor) under the preferences tab it gives the option for setting either the change in temperature that triggers reporting (0.25C/0.5C/1C/5C) or the time period between reporting (every 5 min/10 min/30 min/1 hour). I am currently using the change in temperature to trigger reporting but it does have the down side that if the temperature is fairly stable it can go several hours between reports.
