New purchase of C8 Hub. Have successfully installed C8 Hub, first device installed was a Zigbee bulb, works in Hubitat and after I initiated Alexa skill for Hubitat, I can use Alexa to turn on bulb either manually or within an Alexa routine.
Second device is a S31 lite Zigbee smart plug. Again it works directly in the Hubitat apps, but is not showing up in Alexa as a device I can control. I have rebooted Hubitat server, also tried redoing Hubitat skill in Alexa, but not seeing the plug. Other things to try? TIA
Did you authorize it in the Alexa app on Hubitat, as it sounds like you did for the first device?
Thanks so much, I have worked with many hundreds of apps over the years, and hopefully my learning curve is now over the hump on this one. Again, thanks!
