Hello. Anyone had luck to run Sonoff MINI‑ZBRBS shutter controler ? Maybe under generic driver?
I have installed a MINI-ZBRBS on a roller shutter (replaced a Fibaro FGR-223). Unfortunately it is working only with the "Generic Zigbee Shade" driver. Using this driver I can't find a solution to configure the Switch to toggle mode (to press the button once for Up/Down until the roller completed to open or close), moves only while I keep the wall button pressed.
According to the instructions available on the Sonoff website, the way the connected switch operates can be altered directly using its push button to cycle between its three modes.
