I just purchased a Sonoff SNZB-02WD temperature / humidity sensor. I installed Tuya multisensor 3 in 1 driver via Hubitat Package Manager. It seemed install without any problems. I am getting nothing but error messages. Thanks for any help or suggestions.
I'm have one of these and I'm using the built in 'Sonoff Zigbee Temperature/Humidity Sensor'.
Working a treat for me.
EDIT: It looks like it first paired using one of Markus's drivers.
Thanks for the reply!
I installed with the same driver.
Maybe I need to go through the old uninstall / install routine.
I would change the driver to 'Device' and then hit all the delete buttons to delete schedules, states etc.
Change to the built in driver.
Put hub in pairing mode and re-pair the device.
Hopefully all will then be good. ![]()
I use kkossev's driver for my Sonoff Temp Humidity sensors SNZB-02D, it should work with the 02WD as well. It gives some advanced preferences you don't get with the built-in driver.
Thank you for the thoughtful reply!
Working with the Tuya driver.
Thanks for the help!
That’s a known issue in the latest beta platform version.
I won't struggle then!
Waiting patiently for a fix.
Thanks for all you do!
Events and Log are back!!
Thanks,
Just loaded this for use with an "02D".
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead on line 1469 (method updated)
Thank you for the report, the exception should be fixed in the latest dev. branch version 2.0.2 '2026/02/01 10:15 PM'.
