Sonoff basiczbr3 alternative
Greetings.
I have been using the sonoff basiczbr3 for dumb lights to connect them to hubitat.
I know most recommend upgrading the switches in the wall instead. But sadly that isn't an option since in my country the wall switches are too small to fit them. So question is.
Does anyone know a good alternative to the sonoff switch since sonoff apparently stopped making them?
Thank you in advance.
You could use these, and put the whole thing into a small project box.
Not a bad idea. I'll take a look and see if they or something similar is easy to get here.
Hi Steffen...
I'm in similar position at this moment, the ZBMINIR2 worked for you? If not I'm would like to know what was your final solution?
Thank you!
Vicente
