Somfy RTS Driver Connection/Time Out Issues
I've been using the Somfy Hubitat Driver from @defunctzombie which is great with general succcess however lately having increasingly recurring failures where the blind doesn't stop at the position the system thinks it is i i.e. instead of stopping mid-way it continues to close 100%. I can see the driver sends the command to stop the shade at the set level however the shade keeps on going and the logs are showing "read time out" but not much else that I can tell. Seems the "stop" signal is not getting through.
I had this issue before when I had setup multiple shades being controlled at once and I figured it was jamming the Somfy controller. This is now happening when isolating operation of one shade at a time. Not sure what else to check if anyone has any ideas on potential solutions I would appreciate it!
