Some global variables and connectors never update
Strange behavior: call for @support_team
I have some global variable and linked connectors that never updates. On the rule array itself and some on the tiles...
I changed manually a variable string (Light.kitchen.last) to 4 dashes .... but it still displays (on a tile) an old value (days ago) of 20h18, whatever my changes.
Today I set a new global variable (number) with the right connector and the value changed on the rule array but NOT on the tile (even set correctly with attribute)... always has a value of 0 (when I set the variable value when creating it).
global%20variable%20connectors%20tiles
*Edit: I removed the variable and the connector. Recreated the same variable/connector (string) with another value (11:20) and created a rule to update the value of the string (time) when a switch is triggered. Same result: the value with the global variable array is changed but the tile never update.
global%20variable%20connectors%20tiles%202
*Edit 2: I noticed a difference in the rule array: the variable that does not update on tile has NO * on the array itself. What's the meaning of this * and why this * is not present in this faulty variable update ? Same for my faulty GeoFan counter variable !
no%20star
*Edit 3: created a new global variable, global.test (string) and added it in my rule that change the Light.kitchen.last variable: the global test variable is updated (but still not the Light.kitchen.last variable). If I change on the tile the Light.kitchen.last connector for another one (Light.stairs.last), the tile updates !
last%20rule
global%20test
