Do you have a link to the old custom driver? It's possible that the driver was issuing a "refresh" command to get the sensor to report temp more often. Usually the reporting interval is a function of the device firmware and cannot be changed by the controller.
You have to be careful doing that with battery powered devices. It will greatly shorten the life of he battery. So, you should only do it where absolutely necessary.
How interesting... mine didn’t seem to do that. I just checked another window of mine and notice that it is working correctly (i.e. the way yours is)
I’ll remove the device and re-pair it and see where that goes. I wonder if the temp swing in the fridge is too small to see a difference. It usually hovers between 34 and 37.
The sensor may have a minimum temp change before firing an event. Looking at the temps in my screenshot it looks like The temp differences seem to indicate that it only reports changes over 1.7 degrees.
If you check line 267 it will do a refresh every 5 min on smart things using this driver.
From SmartThings smartsense motion sensor default DTH.
zigbee.temperatureConfig(30, 300)
This line in the configure method means a minimum of 30 seconds, maximum 300 seconds. So if the temperature changes a degree it will report it at least every 30 seconds. If it doesn’t change it will report it at 5 minutes.
So the device itself will send responses at those intervals but SmartThings then chooses to update its temperature event when isStateChange=true (that is the event SmartApps use). So this usually only happens when the temperature actually changes a degree.
Since he has the generic zigbee driver in hubitat it depends on what that has set this to.
No, it won't. It does a single refresh. There is no scheduling of a refresh job every so often. zigbee.temperatureConfig, will configure the reporting of the device, not perform a refresh from the hub.
That's what the command is. But I don't own one so I can't say that it definitely will do that. What I was checking if there was anything "special" in the driver that would cause a reporting to happen and there isn't. For example a cron job running the refresh command every 5 mins.
I have 4 of these and 3 of them report the temperature regularly and correctly. I have one that is stubborn and only updates when you refresh it or the contact is triggered. I would be very interested in getting this one to "behave" or a way to poll it.
I have only 1 of these sensors. It does not update the temp. It has been reporting 48.2 for weeks. Well since I installed it. How can I get this to report correctly?
