[Solved- Twice !] Google Home Built In App "Big Decimal Error" hubitat slow
Can you post a screen shot of the current states section of this specific sooff device?
The issue is that a specific required attribute value that should be populated in fact isnt...
Sure, thanks for responding
My guess is that you are using a ds18b20 temperature sensor so it is not reporting humidity. You can comment out or delete "capability "Relative Humidity Measurement"".
"Guess" haha , that's exactly what the deal is.
You guys never cease to amaze me:grinning::grinning:
Thank You.
While we're at it , for my std sonoff wifi switch, i see in the logs
sys:12019-03-25 09:44:25.594 pm warnReceived data from 192.168.0.25, no matching device found for 192.168.0.25, C0A80019:4A93, 5CCF7F7A17A4 or C0A80019.
here is the device config
How did that device get added? Was it discovery or through the manual method in the Sonoff Connect app? I didn't think either method would create a device network id with the port number: i.e. xxxxxxxx:0050,
I don't think i would have added the port number, so I suspect the discovery app. I have used the manual portion of app, but only ever putting in the IP address.
It was easy enough to fix, I mean it always worked anyway.
Thank You
