[SOLVED] moving a WD500Z-1 from C4 to C7 (changed title to reflect the solution for ease of search)
I have two Linear wd500z-1 dimmers. They are old and finicky, but they work fine once paired.
I'm moving from a C4 to C7 which requires me to Reset the dimmers then include them to the C7
The instructions say:
This could mean you have to set the controller to exclusion .... etc
OR it could mean there is a Z-Wave Reset command that could be sent to the device.
Is there a Z-Wave Reset command? If so does anyone have a few lines to show me how its done?
I have tried the sequence of tap top 5 times then hold the bottom or 15 seconds -- no go. After trying it >10 times and in between praying to the Z-Wave gods. still -- no go.
John
Hi think it means you should “Reset” the device by doing its Factory Reset procedure.
That will then allow it to be Included on the new Hub.
But that is the procedure :frowning:
The words "RESET UNIT" with your controller is what makes me think there may be a Z-Wave reset command.
Sorry, just throwing out suggestions from the other side of the world. :blush:
It’s a device we don’t get to play with but I guess you’ve also tried pulling the Air Gap switch, which would completely power down the dimmer and then inserting it and trying again ?
[SOLVED]
Ignoring the instructions (or perhaps not understanding them) I found a repeatable method to transfer a WD500Z-1 from my C4 to my C7.
  1. Using a Z-Stick S2 I deleted the dimmer. Put the S2 in the exclusion mode, tapped the top (then bottom) once and the S2 showed the device was excluded.
  2. Simply included it into the C7. I tapped the top then 10 seconds later the bottom. Because the delay in announcing an inclusion I'm not sure which tap did the trick. But I don't care.
I performed the same steps on a 2nd dimmer and everything went smoothly.
I had similar issues with old wd500z-1 dimmers: Even though I had excluded them from my Vera controller before trying, I could not include them on Hubitat. I ended up using a Aeontec Minimote to exclude the dimmer (press/hold the "-" button to put remote into exclusion mode, then double tap the down button on wd500z). After doing this I was able to add the switch to Hubitat by entering inclusion mode and pressing the up button once.
