After updating to 2.1.6.118 my options for disabling motion lighting events are no longer working.
I have a Motion Lighting App setup for my home office and have selected my "WFH" switch as the "switch to disable turning off" and "modes to disable turning off" has "Working From Home" selected. I currently have "WFH" (virtual switch) on and my current mode is "Working From Home" however my lights keep going off on me. I've tried setting one or the other, "switch to disable turning off" or "modes to disable turning off" and that doesn't work either.
OK. So opening the rule and clicking done didn't resolve the issue.
With my issue opening the rule and clicking done resolved it. I had a switch that disabled the rule in mine as well.
You must have a different issue.
Next step would be to post a screen shot of how you have the ML set up, and the cog wheel and events pages for it. Also open a log window and grab a sample of what is logged when it goes off when you dont expect it to.
That's very odd. And it happened over a minute later. I'll look into the code for that a bit deeper to see what could possibly cause that. In the meanwhile, could I suggest that you remove that instance of Motion Lighting, and recreate it. See if it still does the same thing.
If you could catch it during that one minute, take a screenshot of the App Status again. Especially interested to see the Scheduled Jobs section during that minute, but also Application State. Don't need Settings.
Iβm having the same or similar issue in the latest version. After upgrading I my motion lightings stopped working. What I noticed is that my light switches donβt show the right status after motion turns it off at times.
Whoa, that's weird. There is NO scheduled job at all. So it's not like Motion Lighting has scheduled that 1 minute turn off -- something else is causing it.
This is actually not at all similar to the issue being discussed in this thread. You will have to show the Motion Lighting setup page, and logs that show what problem you're having.
