Ahh I see now. Yeah it works as intended but I guess not the way I expected it to.
If I type in... http://[ip address]/apps/api/5/hsm?access_token=[access token]
it returns... {"hsm":"disarmed"}
I wanted to get it working with the HomeHabit app but that uses the Get All Devices url and HSM is obviously not part of that list. I'm not even sure HomeHabit would recognize it anyway, so I'll look into controlling it another way (probably using virtual switches).
Thanks - except I can't find the "33" for Away Mode in your example. I created a few also, but can't figure out what to click on to reveal it in the URL.
I was using a scene activator device previously, but am tweaking it to just change the mode, and then have RM manage it based on "set scene per mode" and then have them all in one clean rule.
Ah, I see - perfect, thanks! I'm super noob to anything api or app dev level. Mostly just familiar with logic/rules and still new to hubitat on that end!
Thanks sir, and glad to hear you are still tweaking too - seems it never ends ha
Why am I gettin a invalid token message when I do this? It 100% is the right token. MakerAPI is 150 and the Modes Manager is 141. I tried both but I get the same. Has the spelling changed in recent updates?
Either the app number is incorrect, or the token is incorrect. BTW, the app number should be for the instance of MakerAPI that your integration is using.
Thx for the answer. I'm using 150 for the MakerAPI that's the number showing when I open its page in the browser and it works for sending commands to devices, together with this very same token, all is working fine.
How do I find if there's another instance of MakerAPI with another app number? AFAIK, I only have one instance of MakerAPI, as I only installed it once and only have it once on my list of apps.
I'm feeling ashamed.... It was as simple as an extra letter that somehow, found its way into the middle of the access token. All is well when it ends well....
