[SOLVED] Looking for a compatible G95 Globe with Zigbee
Hi,
I'm looking for a compatible G95 Globe E27 with Zigbee Protocol for a Designer Lamp which I want to make smart.
I've seen one of the brand "Paulmann", "LEDVANCE" and "EGLO"
but none of them are in the "Compatible Devices" list from Hubitat.
Any suggestions?
Or maybe even someone who got a G95 Globe E27 working with Hubitat?
Thanks in advance.
LEDADVANCE is listed as a “standard” Zigbee protocol bulb - should work.
Thanks for the info.
Just in case someone in the future is facing the same problem / question and is searching the forum:
It works ! :slight_smile:
I've bought a single bulb:
LEDVANCE SMART ZigBee Filament Globe 52 DIM 6W 824 230V Gold E27
Hubitat Dashboard
Devices
Add Device
Add Device manually: Zigbee
Start Zigbee pairing
Plug the Ledvance bulp in.
Hubitat found the bulb without any problems or additional hubs / gateways needed.
