[Solved] Hub Variables reporting error
Hi all,
After the last update to version 2.4.0.151 on C7 hub, I'm getting below error when I'm trying to view the hub variables. I tried to revert back to version 2.4.0.148 but issue still persist.
Do anybody experienced the same issue/bug/behavior last days please?
This is a database issue. Try to restore a recent backup to see if that will fix it first. If it doesn’t I have something else we could try, but it’s not the preferred method.
I restored my hub with the recent backup but issue still persist.
May I ask you for another hint please?
Thanks in Advance
Two additional thing. I can see the global variables in webCoRE and pistons are properly getting the values that are set up to global (hub) variables.
Below is the error message from the logs:
groovy.lang.MissingMethodException: No signature of method: java.lang.Double.length() is applicable for argument types: () values:
Possible solutions: next(), getAt(java.lang.String), with(groovy.lang.Closure), each(groovy.lang.Closure), wait(), every() on line 255 (method hubVar)
Okay, this will work if you’re not using variable connectors (if you are stop and we’ll ask before going forward). Go to Settings | Hub Variables like before, but change “configure” to “status” in the URL and hit enter - this will give you a “Remove” button. Push it, and then go back to Settings | Hub Variables - this forces a reinstall of the Hub Variable app.
I followed suggested steps but I did not get any REMOVE button.
By the variable connectors, do you mean the "Dashboard variable device" ?
Get rid of the /hubVar
Variable connectors were the old way of allowing variables to be displayed/used on the dashboard and other apps. (They now have direct access methods so many/most people have never used them.)
Without using /hubvar I got the below page.
Do you want me to use the "Remove Hub Variables" please?
That's the one. Sounds scary, but comes right back.
THANK YOU VERY MUCH!
Everything is back and working fine now.
