Hi There i have my Hubitat "exposed" to the internet, however i have changed the entry port on the Router to something else than port 80, also acces is only allowed from one outside static IP address...
but recently i havent been able to connect to the webinterface from outside... it works fine on the LAN side...
has Hubitat changed something in the webinterface itself to deny access if the IP isnt Local ?
my network setup is unchanged (and yes the recommendation is not to exspose the HUB to WAN) but it really isnt in my setup as only this one IP address is allowed to access it (Edgerouter)
it works fine for everything else in my network as it has always...
EDIT: I just read that it was implemented as a security measurement for FW: 2.2.9 (I jumped from 2.2.5 to 2.3.2 so didn't notice this changelog...)
Dang it... i dont not want to hassle with a VPN setup just for this one interface (but i get the idea if people just exposes their HUB without any security measures)
If you don't want to setup a VPN for admin stuff, you can subscribe to remote admin service. That said, most routers have it built in and is usually easy to set up.
I use the mobile app and when my mobile device isn't on my LAN I can't connect to my hub unless I connect through remote admin. Are you saying that there's a workaround to connect to my hub without remote admin enabled when I'm not on my local LAN?
