Trying to set a clock on a thermostat; I use the "zwave.clockV1.clockSet" class:
def nowCal = Calendar.getInstance(location.timeZone);
def a = zwave.clockV1.clockSet(hour: nowCal.get(Calendar.HOUR_OF_DAY), minute: nowCal.get(Calendar.MINUTE), weekday: nowCal.get(Calendar.DAY_OF_WEEK)).format()
log.debug a
That code in ST logs "8104F02F" and properly sets the clock; but in Hubitat it logs "8104", and the clock is not set; it looks as if the actual time portion of the command is not included...
I get something logged which seems to make sense ("8104F324", for example); but I still don't see the clock changing; not sure if it's because the format() function doesn't really return a character string but some different data type/object.
For the record, the code snippet above works perfectly fine to set the clock; it's equivalent to the result of zwave.clockV1.clockSet(...).format() call that I mentioned in the original post. The problem I was seeing was due to an incompatibility between Hubitat and ST in terms of how the two treat lists of concatenated commands.
And I understand that this will become irrelevant when the next version is pushed and clockSet is supported natively.
