[Solved] All Z-Wave Switches Stopped Reporting Current State
Looking in your details list, I see a lot of devices trying to route through things that no longer show the hub as a neighbor. This could be where its getting all jammed up.
Keep the hub outside of the cabinet. Try running repair on just node 0x0007. Then you could also try running it on a few of the other devices near the hub that should work as repeaters to the hub. Wait a few minutes and refresh the stats. See if the topo map shows any new blue marks on 01.
The other thing I see in the other details list you sent me is 3 instances of a USB stick (PC_CONTROLLER), and one other ghost node. You should try to remove these if you can. How To Remove Ghost Devices using hub tools or a UZB Stick <-- Check Section 3
