SMS not working
I just tried using the SMS feature to send a text to my phone for the dashboard setup and I never got it.
Yes I checked the log and nothing there.
Did you added +1xxxxxxxxxx to your number?
Works for me.
There is a 10 SMS message limit per day, in case you've hit that...
First time using it and yes it's the right format.
Mine isnt working either.
I got an SMS this morning but it came in 14 minutes after the Pushover notification that was assigned to the same HSM event.
Mine never came. All 3 SMS tests failed for my verizon phone.
I'm on Verizon on the east coast. My test text messages came through for a rule on my vibration sensors. And also with HSM I got my text alerts.
Now depending on your firmware level you could have problems. When I first started with hubitat in nov2018 the text alerting was hit or miss, at least for me.
What firmware level you on?
huh ?
From the settings page on hubitat web interface. One of the buttons says hub details, click it and it tells you the particular software/firmware version your hub is currently running.
Sign up for IFTT.
