Smoke and CO detector - interconnected AND zwave?
I am looking to replace all 3 of the smoke and CO detectors in my house. I was hoping to find a model that offered built-in interconnection (one goes off they all do) as well as offering zwave so they can be added to HE for alerts, etc. I am not able to find a unit that offers this - am I missing something or making this more complicated than I need to?
Please offer suggestions on your approach :slight_smile:
If they are line powered with a wired interconnect you can use a Zooz ZEN55
Also did you mean CO or CO2?
Yes - I meant CO !
Are your current detectors wired with an interconnect? Battery powered (only)?
I am replacing all 3 of my detectors, they are wired without a interconnect.
You can use regular (non-smart) hardwired detectors, as long as they have an interconnect wire. The next question is whether your house is wired for interconnect, meaning there's a third conductor (usually red) running between the detector locations.
  • If it is: connect all the detectors to the interconnect wire. When any one alarms, they all sound together, and a single ZEN55 on that wire will report the alarm to Hubitat. The trade-off is that it can't tell you which detector went off (well, with interconnect, they all do).
  • If it isn't: you can install one ZEN55 per detector and monitor each one individually in Hubitat. However, the detectors won't sound together; each one only alarms locally.
Keep in mind the ZEN55 is a listen-only sensor. It reports alarms to Hubitat, but it can't trigger the detectors to sound.
Probably not relevant, but I recently installed a First Alert wireless interconnect smoke/co detector in the garage, and one in the house. Works much better, range-wise, than the old OneLink setup. Voice id is a revelation to me. Unfortunately, there doesn't seem to be a hardwire/wireless interface unit that's being sold ("discontinued") as far as I can tell.
Dumb, yes, but I do like the voice and I didn't have to run wires.
I've decided to take this approach, since my hardwiring is not connected.
I've purchased 3 wireless interconnected detectors and 1 ecolink sensor to trigger HE notifications.
detectors: X-Sense Wireless Combination Smoke and CO Detector, XP0H-WN, 3-Pack | 10-Year Sealed Battery (Not Hardwired), Interconnected Alerts, Large 5.7-inch Bracket, UL 217 & UL 2034 Certified: Amazon.com: Tools & Home Improvement
sensor: Amazon.com: Ecolink Zwave Plus Wireless Audio Detector Wireless Audio Detector for existing Smoke/CO sensors, White (FF-ZWAVE5-ECO)
