It seems an recent update in the past couple weeks have broken control of the SmartWings Zigbee driver. The blinds are all connected and I can see the battery levels and state of opening/closing/ set levels changing as i control them with the remote, but the blinds will not Open or Close using open or close, set 0-100 levels or an automation. I am running ver 2.5.2.139, C-8 hardware. I have applied several updates since I first experienced this and now added 3 more blinds and they all act the same. The first blind I had did work at one point, but seems an update broke it.in the last month.
Anyone else having issue with Zigbee blinds and the 'Smartwings Zigbee Shade' driver? or Zigbee devices in the last month?
Before I restore to an older version, I figure I would ask. I have reset them all 4 times, gone thru config again, same result.
I have been in contact with SmartWings and they say they cannot replicate the issue, but did not give me software version, hardware used or any settings. My other Zigbee devices work fine, only 3 of them and further away from the hub than the blinds in the same room as the hub. I did manage a work around by pairing one of the 4 blinds with Alexa and that opens and closes fine. I use a Virtual Contact Sensor and an Automation that triggers Open or Close of the Virtual Contact Sensor based on my 2 illumination sensors and time of day to set the Virtual Sensor to Open or Close and an Alexa routine to then Open or close based on the Contact Sensor via the Hubitat Skill and that seems to work fine. So clearly a Zigbee motor driver issue with Hubitat. Older Zigbee blinds I had using an older motor version worked fine, seems to be the newer Zigbee motor and Hubitat driver that is the issue. I see stats of the blind, battery level fine, just no Open or Close or set 0-100 working.
SmartWings is going to try a C-8 with the latest software version to test for any issues. Not sure how there cannot be any as my new blinds are working fine on Alexa, and one I try to connect to Hubitat just won’t finish pairing.
Just a data point. I have 18 SmartWings Zigbee shades on the built-in SmartWings Zigbee Shade driver. No issues on current beta 2.5.3.111 or any of the hub software versions preceding it. The shades are three yrs old.
Since the state updates but commands do not move the newer shades, this looks more like a motor or driver mismatch than a mesh problem, especially with other Zigbee devices working in the same room. I would compare the motor model and firmware between your older working shades and the newer ones, and check the logs to see whether Hubitat is actually sending the expected shade commands. As a quick test, it is also worth trying the generic Zigbee Shade driver on one failing shade to see if it responds differently from the built-in SmartWings driver.
I have 10 of the zigbee smartwings shades, all use the smartwings zigbee driver and I have no issues. I recall there being a step on the remote to sync up commands that I initially missed and was having issues. Once I worked that out, all commands from the hub worked great. Mine are <1yr old
Yeah the after pairing, do the UP DOWN button and press the P button on the back of the remote. SmartWings gave me the steps and I created videos showing them the failures. They are troubleshooting it with me, but I do not have a lot of hope.
