Smartwings Group Control Q
Using the custom driver found using HPM as I had zero luck w/ the built in driver. All are configured with the repeat command function, and all respond individually.
I have 5 windows in the bedroom all with Zigbee Smartwings blinds. I tried to just build a rule that used a dimmer to trigger all 5 of them. Weirdly, only TWO ever responded. I tried delays between them etc and it was always just the same two that ever responded.
I then loaded the Groups and Scenes app. Now three respond perfectly. My original two that I've had for a while (month) don't.
Any ideas?
I
Please post the rule.
Why did you choose a (I assume virtual) dimmer instead of shade? Is the goal to control the level of all 5 through one interface?
Sorry...That didn't work so I deleted the rule.
But it was basically just setPosition(100) on Window 1...etc
