I got a Smartwings Drapery rod with the Z-Wave 800 LR engine today. I am able to pair the remote which come with it an test that it works but I do not seem to be able to pair it to Hubitat.
I have a C-8 Pro controller running z-wavejs.
According to Smartwings documentation this should work well.
I am seated in Europe and the device is supposed to be EU compatible but there is no info on the device itself stating which frequency its on (it has a correct European power plug). The serial number of the device seem to be WK82T/V.
If so, it may be trying to pair LR (SmartStart defaults to that for LR-capable devices [at least in the US here]), but Hubitat doesn't have a LR option for regions outside of the US yet.
Although I don't recall the process details, I know it's possible to tell SmartStart to pair it mesh instead... Or you could just try pairing the old way (no SmartStart).
If you are on ZWave-JS there might be more information in the z-wave logs.. If something happened during the inclusion process that caused it to fail there should be a lot of information here.. If it's not being picked up due to wrong frequency/etc it won't have anything here..
Just to verify, as I didn't see it in the thread here, have you tried to run an exclude on it first? Some devices have come from the factory already included (usually a test hub at the factory)..
Are these logs in the UI or are there other ways to access them (SSH and on the file system)? I don't see any info in the UI logs. I see that Hubitat go into inclusion mode and then there is nothing in the logs in the UI.
I have tried to exclude it and also did a factory reset (I found instructions for such somewhere online).
It works perfectly with the Generic Z-Wave DT Window Covering driver. The engine includes as these SmartWings engines so I assume its the same engine in the drapes as they use in the tube engines for roller curtains.
The only thing is that I could not use the button on the engine itself to include it. Using the remote which comes with the engine works perfectly.
