Smartthings presence sensor beep volume
Is it possible to set the beep volume of the ST presence sensor?
When activated, the "beep" is very weak making it mostly useless for locating keys or whatever it is attached to.
I see a state variable labeled: bv, which is currently 18. This was at 22 when I first paired the sensor.
bv is related to battery, not the beep.
ok. Maybe the weak volume is just due to the depleting battery.
it isn't adjustable.
Simple concise answer. :sunglasses: Thanks
