As I continue moving devices off SmartThings I ran across a problem.
My original SmartThings Multi Sensors, the ones that use AAAA batteries will accurately report temperatures above 30F. If the temperature drops below that the device will report its a balmy eleven thousand degrees. I have tested multiple devices and they all demonstrate the same issue.
The device driver being used is: SmartSense Multi V1
