Smartthings Motion Sensor Not Pairing Correctly
I am trying to re-pair a smarthings motion sensor. It was recently removed. I am now trying to re-add it to the hub, but now the hub is now acting weird. After the device is found, it comes up as a moisture sensor. When I go into the device to change to change the driver, the drop down window says loading and I am unable to choose another driver.
Update...after waiting it out, it finally let me have a drop down menu..((Weird)).. Did a reboot of the Hub and now it shows motion. Hopefully this isn't apart of a bigger issue.
Seems my issue turned into another problem now...will start a new thread...
