SmartThings Hub Link
“When you hit Save for the SmartApp in the ST mobile app, Send Hub Events will send your device selections to Hubitat. Hub Link will create virtual devices for each SmartThing device with the same name as in SmartThings.”
This isn’t happening for me. Not sure what I’m missing or misunderstanding? I have the Hubitat Hub Link app installed pointing to my SmartThings IP and I have created the SmartApp on ST. Selected the devices to monitor and tapped save, but I don’t see a virtual device with the same name on Hubitat.
Did you put in the IP of the Hubitat hub? Also, you can turn on the logging option, and look in Live Logging to see the messages Send Hub Events attempts to send to Hubitat.
Fortunately it’s mandatory to enter the Hubitat IP to save the SmartApp config :grinning:
Got it working! Thanks for your assistance Bruce. I deleted the SmartApp and created it again. Probably an issue with the code I pasted. I didn’t click on RAW from the repo when I copied it the first time. Might have been the cause. Perhaps something you should add to the instructions.
By the way, there’s a typo in step 2 of your instructions (something I do all the time ) :grinning:
“The IP address of you Hubitat Elevation Hub…”
