Smartly inject not working in 2.3.3 (Now working in 2.3.4?)
Por favor, intente limitar sus preguntas sobre el mismo problema a un solo mensaje. Puede ser más difícil responder a las preguntas de un usuario si se distribuyen en varios mensajes.
Pregunto en todos los sitios donde se hable del problema que tengo, porque puede ser que en un hilo haya más gente que le pase que en otro.
I know this thread has been quiet for a little bit, but I'm running into issues with Smartly Inject. I can get the PAW and everything to appear fine. I can move tiles and resize them. I even get the notification "There are unsaved changes!" I click save and all is fine and a message appears, "Changes saved!" However, when I unclick the paw, everything goes back to the original layout.
Is it dead?
Fresh install with everything at latest versions and I get Uncaught TypeError: Cannot read properties of undefined (reading 'map') at for (var d = 0, u = h.tiles.map((function(t, e) {
Paw won't show :frowning:
Now I have to edit 72 tiles by hand, boo hoo
I think you might be right. Must be one of newest hub updates as it just worked for me a month ago.
So is smartly dead? Would be a shame. I’ve tried easy dashboards and it still feels like MySpace.
My work on it did not eventuate in the end. Some got it working I thought, without needing it to be updated. I can't see me taking it on like I indicated previously.
You had to make the changes in the setting pages of the dashboard and then click save or something like that. I quit using it after getting tired of having to do all that and use simple CSS editor. Not as many options. But it works for what I need
Yeah unfortunately no way to edit anything anymore. I am still using it but can’t change anything or add anything.
Hopefully my CSS editor will go the way of many things lately, absorbed or re-developed in(to) the platform. There’s nothing that is rocket science, just time and effort, which could quite likely be done better or more efficiently nowadays with modern tools or just a different approach.
That said, it is a good example for someone to use artificial tools to expand with similar patterns.
