[smartly][css] removing icons (remove, hide)
Change tile-# to the tile your targeting.
#tile-9 .tile-primary:before{display:none;}
or to remove icon from all dash link tiles use
.tile.dashboard .tile-primary:before{display:none;}
OK, tile-specific, just like individual device tiles...
Can't remember what I tried. Maybe just as well, it might be embarrassing. :wink:
The "global" one, that's what I tried. Must have got the syntax wrong.
I believe the correct technical term is "Bingo!" Thanks!
You should try out this for dashboard links instead. They work for local as well as remote with a single button.
Wow :eyes: since when was that an option?! Is this the C-7 hub?
This is a C7 hub but it's available on C5 since before the C7 release I think. I've had it for a while now.
Ah I'm C-4 here. Good to know HE is working on the dashboard though!
That does not look very stock...once again I remember why I should not look at other people's dashboards, unless I feel like I want a can of "Whup-a$$" dumped on me. :wink:
It's probably available on c4 too. It was just an update to the dashboard app.
It's stock, I just stuck Emoji's in the dashboard name. They're like contact sensors... I stick em on everything.
Update called ___________ ?
Ahhh...didn't know/think you could do that. :slight_smile:
Base hub software.
Thinking of your twins again... :wink:
Ohhhhhh. Heck dude, that's good thinking.
Yea, sorts em for me. I'm a little weird and want things organized certain ways.
I've found that if you stalk @lewis.heidrick a bit you will learn useful things.
https://emojipedia.org/
Just c/p as needed anywhere in HE (and most other apps, I use them now for my AutoTask ticketing too)
im not running smarthly but how do you remove the "dashboard text", all mu dashboard links say dashboard at the bottom
Change tile 9 to the one your targeting. (.tile-title is the bottom one - .tile-secondary is the top one). FYI smartly does it automatically along with many other common 'fixes'
#tile-9 .tile-title,
#tile-9 .tile-secondary {
  display: none;
@BorrisTheCat to move presence icons and words them with this (use - numbers to go up if you prefer) the 'not-presence' syntax might need some help, both mine are here, it the grill is hot so gotta run.
.tile.presence .material-icons{
  position:relative;
  top:75px;
.tile.presence .tile-primary.present>div{
  position:relative;
  top:75px;
.tile.presence .tile-primary.not-present>div{
  position:relative;
  top:75px;
individually
#tile-123 .material-icons{
  position:relative;
  top:75px;
#tile-123 .tile-primary.present>div{
  position:relative;
  top:75px;
