SmarthomeDB Curtains Driver Needs Fixing
I got this driver from SmarthomeDB for their curtain controller device. I think they did a real quick and dirty conversion from their Smartthings code. It seems buggy, though. I asked them for support and they kinda just stopped responding. Ugh.
The code does actually work. I can control the curtains. However it's really difficult to do automation rules because of some oddities. I was hoping I could get some help fixing up the driver to resolve the issues below. The driver code is available here.
  • The On/Off state always reports as NULL
  • The Closed/Open state isn't quite right. It checks for CLOSED, but it reports CLOSE causing a incorrected False in the Rule Machine logic.
  • It spams the log with these messages every few minutes. (I don't know if this is a problem or not.)
dev:5452020-10-03 01:47:18.755 pm warnjava.lang.NullPointerException: Cannot invoke method endsWith() on null object
dev:5452020-10-03 01:47:18.751 pm debug[raw:catchall: 0000 0013 00 00 0040 00 76FE 00 00 0000 00 00 00FE76D3A0AE14004B12008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:76FE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, FE, 76, D3, A0, AE, 14, 00, 4B, 12, 00, 8E]]
dev:5452020-10-03 01:46:56.758 pm debugJust Closed mode null
dev:5452020-10-03 01:46:56.755 pm debug
dev:5452020-10-03 01:46:56.752 pm debug100
dev:5452020-10-03 01:46:56.749 pm debug[raw:76FE0101020808002064, dni:76FE, endpoint:01, cluster:0102, size:08, attrId:0008, encoding:20, command:0A, value:64, clusterInt:258, attrInt:8]
dev:5452020-10-03 01:45:56.726 pm debugJust Closed mode null
dev:5452020-10-03 01:45:56.723 pm debug
dev:5452020-10-03 01:45:56.719 pm debug100
dev:5452020-10-03 01:45:56.716 pm debug[raw:76FE0101020808002064, dni:76FE, endpoint:01, cluster:0102, size:08, attrId:0008, encoding:20, command:0A, value:64, clusterInt:258, attrInt:8]
That site says the code was updated 44 minutes ago.
The code that is there is incomplete. It includes a Capability Switch, yet has on/off commented out. One or the other is wrong. :slight_smile: Same for Configure, setPosition and levelOpenClose
I've cleaned up what I can, but since I don't own shades, I doubt I can do more.
New Code
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0 *  * Unless required by applicable law or agreed to in writing, software distributed under the License is distributed * on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License * for the specific language governing permissions and limitations under the License. * 2017 */
metadata {
    definition(name:"Curtains", namespace:"SmartHomeDB", author:"SmartHomeDB: Ray Zheng") {
        capability "Actuator"
        capability "Configuration"
        capability "Refresh"
        //capability "Switch Level"
        capability "WindowShade"
        capability "Switch"
        fingerprint deviceId:"0104", inClusters:"0000, 0001, 0005, 0004, 0102", outClusters:"0019", manufacturer:"SmartHomeDB", model:"093199ff04984948b4c78167c8e7f47e"
    command "levelOpenClose"
    preferences {
    	input name:"mode", type:"bool", title:"Set SmartHomeDB Curtain Direction", description:"Reverse Mode ON", required:true, displayDuringSetup:true
      input name: "debugOutput",   type: "bool", title: "<b>Enable debug logging?</b>",   description: "<br>", defaultValue: true
def configure() {
    if (debugOutput) log.debug "Configure"
def updated() {
    if (debugOutput) runIn(1800,logsOff)
/* Parse incoming device messages to generate events
		specification: windowShade - ENUM ["opening", "partially open", "closed", "open", "closing", "unknown"] <-- these are the only
		values that attribute "windowShade" may contain
    def parseMap = zigbee.parseDescriptionAsMap(description)
    def event = zigbee.getEvent(description)
    if (debugOutput) log.debug(parseMap)
    try {
        if (parseMap.raw.startsWith("0104")) {
            if (debugOutput) log.debug "Curtain"
        }else if (parseMap.raw.endsWith("0007")) {
            if (debugOutput) log.debug "running…"
        }else if (parseMap.endpoint.endsWith("01")) {
            if (parseMap["cluster"] == "0102" && parseMap["attrId"] == "0008") {
                long theValue = Long.parseLong(parseMap["value"], 16)
                def eventStack = []
                if (debugOutput) log.debug(theValue)
                if (debugOutput) log.debug(mode)
             if (mode == true) {
                if (theValue > 95) {
                    if (debugOutput) log.debug "Just Closed"
                    eventStack.push(createEvent(name:"windowShade", value:"closed"))
                }else if (theValue < 5) {
                   if (debugOutput) log.debug "Just Fully Open"
                    eventStack.push(createEvent(name:"windowShade", value:"open"))
                }else {
                    if (debugOutput) log.debug "Motion"
                    eventStack.push(createEvent(name:"windowShade", value:"unknown"))
             else {
               if (theValue < 5) {
                    if (debugOutput) log.debug "Just Fully Open mode null"
                }else if (theValue > 95) {
                    if (debugOutput) log.debug "Just Closed mode null"
                }else {
                    if (debugOutput) log.debug "In Motion"
                return eventStack
        }else {
            if (debugOutput) log.debug "Unhandled Event - description:${description}, parseMap:${parseMap}, event:${event}"
        if (event["name"] == "switch") {
        	if (debugOutput) log.debug("add event: ${event}")
            return createEvent(name:"switch", value:event["value"])
    }catch (Exception e) {
        log.warn e
def off() { close() }
def close() {
    if (debugOutput) log.debug "Set Close"
	if (mode == true) {
    zigbee.command(0x0102, 0x00)
    }else {
    zigbee.command(0x0102, 0x01)
def on() { open() }
def open() {
    if (debugOutput) log.debug "Set Open"
	if (mode == true) {
    }else {
def setPosition(val) {
    if (debugOutput) log.debug "unImplemented: Set Position $val %"
def levelOpenClose(val) {
    if (debugOutput) log.debug "unImplemented: Set Level Open/Close"
def refresh() {
    if (debugOutput) log.debug "refresh()"
    zigbee.command(0x0102, 0x02)
def logsOff(){
	log.warn "debug logging disabled..."
	device.updateSetting("debugOutput",[value:"false",type:"bool"])
Thanks. It was "updated" 44 minutes ago after my original post because that's when I posted it. I've been using that code as-is for at least a year. It's what the manufacturer sent me. shrug
Thanks for cleaning it up a little, though. Hopefully I can do some RM on it now at least.
