Here is my execution this morning, I am only running every 5 min.
app:462018-05-31 06:46:12.364:debugHumidityHandler:Turn Fan off in 45 minutes.
app:462018-05-31 06:46:12.362:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:46:12.359:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:46:12.358:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:46:12.357:infoHumidityHandler: humidity = false
app:462018-05-31 06:46:12.356:debugIsHumidityPresent: returning false
app:462018-05-31 06:46:12.354:debugIsHumidityPresent: states date is true
app:462018-05-31 06:46:12.353:debugIsHumidityPresent: states date is true
app:462018-05-31 06:46:12.352:debugIsHumidityPresent: states date is true
app:462018-05-31 06:46:12.351:debugIsHumidityPresent: states is true
app:462018-05-31 06:46:12.351:debugIsHumidityPresent: humidity: 49
app:462018-05-31 06:46:12.350:debugIsHumidityPresent: humidity: 48
app:462018-05-31 06:46:12.349:debugIsHumidityPresent: humidity: 46
app:462018-05-31 06:46:12.348:debugIsHumidityPresent: numStates is 3
app:462018-05-31 06:46:12.270:infoHumidityHandler:running humidity check
app:462018-05-31 06:41:12.418:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:41:12.415:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:41:12.414:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:41:12.413:infoHumidityHandler: humidity = true
app:462018-05-31 06:41:12.412:debugIsHumidityPresent: humidity rate above incrate
app:462018-05-31 06:41:12.411:debugIsHumidityPresent: states date is true
app:462018-05-31 06:41:12.410:debugIsHumidityPresent: states date is true
app:462018-05-31 06:41:12.409:debugIsHumidityPresent: states date is true
app:462018-05-31 06:41:12.408:debugIsHumidityPresent: states is true
app:462018-05-31 06:41:12.407:debugIsHumidityPresent: humidity: 47
app:462018-05-31 06:41:12.406:debugIsHumidityPresent: humidity: 49
app:462018-05-31 06:41:12.406:debugIsHumidityPresent: humidity: 48
app:462018-05-31 06:41:12.404:debugIsHumidityPresent: numStates is 3
app:462018-05-31 06:41:12.289:infoHumidityHandler:running humidity check
app:462018-05-31 06:36:12.372:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:36:12.369:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:36:12.368:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:36:12.367:infoHumidityHandler: humidity = true
app:462018-05-31 06:36:12.366:debugIsHumidityPresent: humidity rate above incrate
app:462018-05-31 06:36:12.365:debugIsHumidityPresent: states date is true
app:462018-05-31 06:36:12.364:debugIsHumidityPresent: states date is true
app:462018-05-31 06:36:12.363:debugIsHumidityPresent: states is true
app:462018-05-31 06:36:12.362:debugIsHumidityPresent: humidity: 46
app:462018-05-31 06:36:12.362:debugIsHumidityPresent: humidity: 47
app:462018-05-31 06:36:12.361:debugIsHumidityPresent: humidity: 49
app:462018-05-31 06:36:12.360:debugIsHumidityPresent: numStates is 3
app:462018-05-31 06:36:12.280:infoHumidityHandler:running humidity check
app:462018-05-31 06:31:12.425:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:31:12.421:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:31:12.421:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:31:12.420:infoHumidityHandler: humidity = true
app:462018-05-31 06:31:12.419:debugIsHumidityPresent: returning true
app:462018-05-31 06:31:12.418:debugIsHumidityPresent: states date is true
app:462018-05-31 06:31:12.417:debugIsHumidityPresent: states date is true
app:462018-05-31 06:31:12.416:debugIsHumidityPresent: states is true
app:462018-05-31 06:31:12.415:debugIsHumidityPresent: humidity: 46
app:462018-05-31 06:31:12.414:debugIsHumidityPresent: humidity: 47
app:462018-05-31 06:31:12.413:debugIsHumidityPresent: numStates is 2
app:462018-05-31 06:31:12.296:infoHumidityHandler:running humidity check
app:462018-05-31 06:26:12.422:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:26:12.419:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:26:12.418:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:26:12.417:infoHumidityHandler: humidity = true
app:462018-05-31 06:26:12.416:debugIsHumidityPresent: returning true
app:462018-05-31 06:26:12.415:debugIsHumidityPresent: states date is true
app:462018-05-31 06:26:12.414:debugIsHumidityPresent: states date is true
app:462018-05-31 06:26:12.413:debugIsHumidityPresent: states is true
app:462018-05-31 06:26:12.412:debugIsHumidityPresent: humidity: 45
app:462018-05-31 06:26:12.411:debugIsHumidityPresent: humidity: 46
app:462018-05-31 06:26:12.410:debugIsHumidityPresent: numStates is 2
app:462018-05-31 06:26:12.298:infoHumidityHandler:running humidity check
app:462018-05-31 06:21:12.424:infoHumidityHandler: FanSwitch.currentValue = on
app:462018-05-31 06:21:12.420:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:21:12.419:infoHumidityHandler: state.AutomaticallyTurnedOn = true
app:462018-05-31 06:21:12.418:infoHumidityHandler: humidity = true
app:462018-05-31 06:21:12.418:debugIsHumidityPresent: humidity rate above incrate
app:462018-05-31 06:21:12.417:debugIsHumidityPresent: states date is true
app:462018-05-31 06:21:12.416:debugIsHumidityPresent: states date is true
app:462018-05-31 06:21:12.415:debugIsHumidityPresent: states is true
app:462018-05-31 06:21:12.414:debugIsHumidityPresent: humidity: 43
app:462018-05-31 06:21:12.413:debugIsHumidityPresent: humidity: 45
app:462018-05-31 06:21:12.412:debugIsHumidityPresent: numStates is 2
app:462018-05-31 06:21:12.305:infoHumidityHandler:running humidity check
app:462018-05-31 06:16:12.463:infoFanSwitchHandler::Switch changed
app:462018-05-31 06:16:12.428:debugHumidityHandler:Fan On
app:462018-05-31 06:16:12.427:infoHumidityHandler: FanSwitch.currentValue = off
app:462018-05-31 06:16:12.423:infoHumidityHandler: ManualControlMode = After Set Time
app:462018-05-31 06:16:12.422:infoHumidityHandler: state.AutomaticallyTurnedOn = false
app:462018-05-31 06:16:12.422:infoHumidityHandler: humidity = true
app:462018-05-31 06:16:12.421:debugIsHumidityPresent: humidity rate above incrate
app:462018-05-31 06:16:12.419:debugIsHumidityPresent: states date is true
app:462018-05-31 06:16:12.418:debugIsHumidityPresent: states date is true
app:462018-05-31 06:16:12.417:debugIsHumidityPresent: states is true
app:462018-05-31 06:16:12.417:debugIsHumidityPresent: humidity: 39
app:462018-05-31 06:16:12.416:debugIsHumidityPresent: humidity: 43
app:462018-05-31 06:16:12.415:debugIsHumidityPresent: numStates is 2
