Smart bulbs
Anyone know of a decent priced zigbee bulb with an e27 base 220v 50 hz? No neutral wires in the switch box. Need a couple of dozen so trying to find a decent price. Thought tradfri would be an option but can’t find any in stock anywhere. Based in Bangkok.
Tia
Mac
One option is to use a relay in the ceiling box where the neutral is, and connect the wall switch wires to the switch terminals of the relay, or to switch neutral to a switch terminal, depending on what you buy. You just have to find the light that has the box with the switch wires coming into it, and the rest of the lights should branch off from that box, for the switch to control all the other lights. It is usually the light closest to the switch on the wall.
Most of those Tuya Zigbee mini relays work on 100v to 240v.
I really like this one I bought below for $9.00, it works as a dimmer or a switch. They don't picture the Zigbee version, but it has a terminal for switch and/or dimmer. It takes a momentary switch connection, so press once and it toggles on and off, and press and hold up or down to dim or brighten. I'm using it for a hall light on a motion sensor, and I found some in-wall momentary switches to put in my switch boxes (you can add as many switches as you want) to control it manually.
https://www.aliexpress.us/item/3256806615452043.html?spm=a2g0o.order_list.order_list_main.131.20421802JW12fW&gatewayAdapt=glo2usa
