Slow/unusable C7 hub
Hello,
Since a couple of days, the hub has become extremely slow, to the point where automations don't run anymore. It's never been fast, that's my biggest issue with Hubitat honestly, but it's always been functional at least. In the past, I had to do maybe a reboot every other week.
Now, I'm to the point where I set up a nightly reboot, and that doesn't seem to solve the issue for more than a few hours. I did not add any rule in the past weeks, nor made any change to the hub (at least no addition, I did remove the Watchdogs app which I was not using, hoping to clear some cpu/mem in the process).
For instance, after 10 minues of loading
I also saw in the log at some point that a RM had timed out after some 200 000ms. No screenshot, cause the logs won't reload now...
I did manage to get a refresh on hub info, and I'm not seeing anything that could explain this:
Thanks!
Maybe @bobbyD could glean something from the engineering logs?
That's never a good thing. Setting nightly reboots is just a band-aid to cover something that is eating your hub, never an effective solution. Please send me a private message and we will take a look at your hub's engineering log. You may want to perform a Soft Reset to see if that fixes your problem.
Yeah the reset was just a temp solution until I figured this out, the previous night the light shortcut I had installed for the diaper changing station was not working because the hub was frozen, and unhappiness occurred :smiley:
I'm proceeding with the soft reset, just have to restore the backup and it's done.
Poking you on a PM!
Thanks for the support :slight_smile:
