Sinopé Thermostat TH112xZB with energy meter - debug logging
I’m looking for a way to stop debug logging on the display backlight using @samuel.c.auclair’s Sinopé TH112XZB thermostat driver. I’ve read through the driver code to see if I could find where it gets recorded, but don’t know enough to find it unfortunately…
This is the version I am using:
https://raw.githubusercontent.com/sacua/SinopeDriverHubitat/main/drivers/TH112xZB_Sinope_Hubitat.groovy
Line 766 has the log.debug line
log.debug("setting display backlight to ${mode} (${backlightModeAttr})")
You can comment it out by putting a // at the front.
// log.debug("setting display backlight to ${mode} (${backlightModeAttr})")
Probably better would be:
if (txtEnable) log.debug("setting display backlight to ${mode} (${backlightModeAttr})")
Even more better :slight_smile: would be to add in a debug switch and preface all the log.debug statements with the conditional.
Line 77 gets inserted:
input name: "debugOutput", type: "bool", title: "<b>Enable debug logging?</b>", description: "<br>", defaultValue: true //csteele
Then we turn it off after 30 min by inserting Line 116:
if (debugOutput) runIn(1800,logsOff) //csteele
Then add in a logsOff method:
def logsOff(){ //csteele
	log.warn "debug logging disabled..."
	device.updateSetting("debugOutput",[value:"false",type:"bool"])
at the very end of the code.
Line 766 then becomes:
if (debugOutput) log.debug("setting display backlight to ${mode} (${backlightModeAttr})")
and then put "if (debugOutput) " in front of any other log.debug you don't want to see all the time :smiley:
Will update the drivers accordingly to correct this bug when I will return home tomorrow.
If you use the logsOff code, you'll probably want an unschedule() ahead of the runIn...
    unschedule()
Obviously every unschedule() in the driver today will terminate the 30 min autoshut, which might make it less desirable to have it at all.
This is awesome! Thanks @csteele and @samuel.c.auclair!
You guys are really great! I really appreciate it. :blush:
Should be corrected the next time you will update the driver through HPM.
Awesome! Thanks!
