Sinope thermostat Can't set time (solved)
Hello,
There is no option, in actions, to set the clock on my Sinope TH1123ZB Zigbee Baseboard Thermostat.
I had a power failure the other night, then found when the power came back on, the display on thermostat no longer displayed the time.
This is not a big issue as I am using Hubitat Rule Machine to change the temperature from time to time, but I like to read the time when I walk by.
I can set the time from Devices, select the Thermostat, then click the "set clock" button, and it is OK.
However, I want to do that automatically when the hub reboots after a power failure.
When making an Action to change a thermostat, there is no option to set the clock.
I can "set heating point", "set cooling point" (although I have no idea why this option is available as the thermostat cannot turn on any kind of cooler), "set mode", "fan setting" (again why as the thermostat cannot control a fan)
There is no "set clock" option.
Must I get with the manufacturer, or is there another way I can do this?
Thanks, Mark.
I would add a new Rule Machine Rule, with a Trigger of Hub Startup. Then for the Action, have it run a Custom Command on the Thermostat. That should allow you to select the "Set Clock" command on that particular device.
Thanks, oglewan, I did not know about custom commands.
I guess there is more then one way to skin a cat.
Mark. :slightly_smiling_face:
