Simplicity Studio® 5 (SSv5) Will it Run on Windows 11
On the Simplicity Studio's website the operating system is listed as Windows 10. Has anyone tested to see if this software will run on a Windows 11 operating system. Will be using with a Z-Wave USB dongle.
Would like to update to a new laptop as the current versions are now mostly Windows 11.
Runs fine on Windows 11
Works fine on Win11 for me too. Just flashed a UZB-7 two days ago.
And it runs fine in a Bootcamp VM on an Intel Mac.
Thank you all so much for confirming that Simplicity Studio will run on Windows 11.
Did a Zen switch upgrade using the C7 hub. It took 12 hours for a 168K file. Using a laptop with the dongle near the switch should be much faster.
It would be nice if there was an optical port on the switch or another way to achieve a FW update in seconds.
Thanks again for the information.
Yeah, that's not going to happen at this price point.
I do all my Zooz upgrades using a z-stick... usually about 5 minutes start to finish: exclude, add to the z-stick, flash, factory reset, include. Tried to use the built-in tool a couple of times and it was so slow i gave up. I suspect it's due to the S2 security
