Simple Virtual Thermostat Temp updater
@napalmcsr I'm not sure as this rule runs perfectly but as you see I have hard coded the setThermostatSetpoint to 71. What I want is this same type of rule but to have the setThermostatSetpoint become the same value as what the virtual thermostat is set at.
Unfortunately the Tesla driver that I downloaded from Tesla Integration to Remind Us To Plug The Car In doesn't recognize the Tesla climate system as a thermostat which is why I'm having to reference the temperature attribute that does allow you to set the temp of the car. Hence the reason for the virtual thermostat as my ultimate goal is to add a Thermostat tile to my dashboard pointed to the virtual thermostat and then have that virtual device send the requested temp to the Tesla via a rule. Once that is all working I can then plan to add a voice command to Alexa .. "prepare Tesla for departure" that will trigger the climate system to come on in the car at the requested temp.
So now back to the question at hand .. what are the Rule 4.0 steps by steps I need to enter in order to have virtual device temp result in physical device (tesla) getting set to the same set point?
