Is there a way to use SimpleRule to setup an automation, so that:
- If system comes out of Away mode(into Day/Night modes etc.), AND if the system was actually in Away before this,
- then turn on a light
I am able to create a rule to say, if mode changes to Day, then turn on the light. But, how do I restrict it to execute that, only if previous mode was Away?
Assuming you mean Simple Automation Rules, then yes: use "Mode Transition" for the "How do you want to trigger it?" option. EDIT: Nevermind, it only allows you to select one mode. Still possible, you'd just need one such automation per mode transition...
Rule 5.0 could do this pretty easily with a predicate condition (which must be true in order for the rule to trigger), however.
If this is easier to implement using rule machine (RM), then I'll give it a try. Can you please give an example how can I setup this in RM, so that the action triggers only if previous mode was away?
Sure! Something like this should work:
Predicate condition: Mode is Away
Trigger: Mode becomes X, Y, Z
(everything except "Away," or really whatever specific transitions you hope to capture)
Actions to Run:
Off: Light
