You are using the conditional action so add an END-IF before the Off and you should be all set.
FYI a simple condition allow for single condition and a single action. Notice there isn't a THEN and no need for an END-IF.
IF (Single Condition true) Action
Hi @rlithgow1 ,
On a short break at work so unfortunately can’t actually write a rule but here’s an explanation of how I do the same thing in RM using a number of simple rules:
RM rule 1. Trigger is Sunset +40min >>> Action is Turn ON outlet
RM rule 2. Condition (rule only runs if following is true) - Patio Delay Off >>>>>Action is Turn OFF outlet at 11:00pm
RM rule 3. Condition (rule only runs if following is true) - Patio Delay ON >>>>>Action is Turn OFF outlet at 1am
Even though it three rules may seem cumbersome, it makes it very easy to change the parameters (Time ON and OFF) easily and at will. It also helps to make sure that it is very easy to trouble shoot if your outlet does not act in the way you expect.
This of course can be done in one rule using various delays as well. What I normally do when I may anticipate wanting to “tweak” my settings in the future is to make a local variable for each value I may wish to change in the future and use those variables in my rule. That way, the variables show up clearly and it is easy to change their values without having to actually go into the Rule itself and change the parameters by calling up each step in the Rule. This is especially true if I write a single rule to cover your use case. IOW, if you write a single rule to accomplish what you want in your example, by having all three parameters as variables (time ON, time OFF when delay OFF, and time OFF when delay ON) you can easily see in one place all the values for these times as they appear in one place and can easily alter the times by just changing their values in the variables chart, rather than having to go in and alter each step in the rule.
Sorry if this explanation does not seem so clear without a graphic example or screenshot of the actual written rule but since I do not subscribe to the Hubitat Remote Access, I can not actually do any Rules creation when away from local access to my hub. Hope this gives you some ideas!
@rlithgow1 One thing you might want to consider is adding the virtual switch to the Off command so you don't have to remember to turn it off after 11:00 or the next day.
