Simple Automation Rules: not working if set on sunset/sunrise with offset
Rule with specific time working fine:
Rule based on sunset time with offset - JUST DO NOTHING:
Switch not operated by second (sunset with offset) rule.
Pls point - if I doing something wrong or expecting something unexpected ?
I’m seeming to have the same problem. I have a simple rule to turn on the garage light and the front porch light @ sunset and off at sunrise but nothing seems to happen. It seems as if sunset is not triggering.
In my case rules started working on next day.
Changing settings not lead to re-evaluation of conditions.
I’ve set a simple automation rule that says turn lamp on at sunset and off at 11pm. This works perfectly.
I then decided to have the light come on earlier so set the sunset offset to -30.
With the offset nothing happens. Lamp stays off unless I use the dashboard or socket switch to switch it on. It then turns off at the scheduled off time of 11pm.
Is this a bug or am I doing something wrong?
I seem to recall something about the event scheduling when using sunrise or sunset with an offset - the event isn't scheduled for the current day, it is scheduled for the next day . . . I'm a bit fuzzy on it.
I think @bravenel knows this inside and out . . .
