I have a simple automation rule that turns on a light when an open-close sensor is open, then turns it off when the same sensor is closed. Their are no restrictions or anything on it. I turned on logging for the rule.
Sometimes it doesn’t work! I get the open and close logging from the sensor, but the rule doesn’t run, and there’s no log for the rule suggesting why it didn’t run.
Ha ha my contractor had unplugged my Caseta hub so that's why it wasn't working this time. Oops. I had tried to check this by turning the lights on and off, but I forgot that the pico remotes communicate directly with the switches, and don't need the hub. Maybe that's why Lutron Caseta has such a high WAF.
BUT why wasn't there any logging from the app? Shouldn't the app have logged that it was trying to turn on and off the lights?
