Simple Automation Rule Bug?
I have a couple of simple automation rules that ran fine for 9+ months but now are inconsistent, and only change has been update to 2.3.3.130.
Its a simple wired door contact to a Zooz Zen 16 which serves as the trigger to switch the light on and off. The log shows the trigger device 483 turning on, the simple automation app 258 giving command to turn on and the light switch 450 turning on. The off cycle also worked but then at the 10:44:44 mark you see the door relay is off but the app never gives the off command. I've repeated this same occurrence several times.
There are no restrictions or delays to the rule and below is the screenshot of rule setup.
Again, never had a problem with this before and I have the same rule and physical setup for laundry room and it has the same problem.
I know I can import into rule machine but I liked having these particular door contacts as separate simple rules, but could try the import.
Any ideas?
