Should Mirror app move under 'Automations'?
Went looking for the Mirror app, expecting it to be listed under the Automations header in UI 2.5.x, but instead found it under Apps. What do you guys think makes more sense?
I mean... it's an automation app, no? LOL
Not using this, and not knowing for sure what it does other than allowing you to have one device mirror another, I would not know for sure.
But to me:
Automations allow you to build rules with "if:then" or more complex logic,
Integrations allow communitation between Hubitat and external systems, and
Apps are what is left.
I would think Mirror could be an automation if you have to build logic similar to Room Lighting. But, if you are simply associating devices to each other, even with just light logic, then I would say it is still an app.
Notifications is an example of an Automation (put in Automations by HE Staff) that doesn't allow/require any rule building with If/Then simple or complex logic, you just click on a device to monitor, and enter the message you want sent if it turns on or off, etc. The app automates notifications (and builds any "logic" it needs in the background). So I don't think that definition fits...
The Mirroring app seems to provide a more complex behavior (also created through a similar simple UI as Notifications) so it seems like it could be considered an Automation. :man_shrugging: :wink:
