Should I pull power to hub?
Not having any problems but was wondering if it would be a good thing to shut down and pull the power periodiically to clear the radios.
If it aint broke……
you asked: if it’s a good thing. And the answer of: if you detect nothing wrong, what are you fixing? is a reasonable answer. However, fixing small, perhaps invisible things can be beneficial. So, sure, reboot, especially if it makes you feel better :smiley: Just be sure to do if via shut down FIRST, then pull power second.
I cannot count how many undetected problems I have fixed when nothing was broken! :shaking_face:
One of my lessons learned, is to put this into play via having the Hubitat Hub on a simple wifi outlet. That way, I can do this activity (power off, wait a number of minutes, reboot), REMOTELY.
