Thanks a lot for taking a look at this. Very highly appreciated
Here is the debug logs;
dev:532026-05-02 00:42:43.332debugskip:hubitat.zwave.commands.multichannelv4.MultiChannelCmdEncap@19b6086
dev:532026-05-02 00:42:43.297debugparse:{"cc":38,"cmd":3,"ep":1,"values":[{"ccVersion":4,"newValue":0,"endpoint":1,"metadata":{"readable":true,"min":0,"max":99,"label":"Current value","secret":false,"writeable":false,"type":"number","stateful":true},"propertyName":"currentValue","commandClass":38,"property":"currentValue","commandClassName":"Multilevel Switch","value":0,"prevValue":15,"ts":1777675363272},{"ccVersion":4,"newValue":{"unit":"seconds","value":0},"endpoint":1,"metadata":{"readable":true,"label":"Remaining duration","secret":false,"writeable":false,"type":"duration","stateful":true},"propertyName":"duration","commandClass":38,"property":"duration","commandClassName":"Multilevel Switch","value":{"unit":"seconds","value":0},"prevValue":{"unit":"seconds","value":0},"ts":1777675363275},{"ccVersion":4,"newValue":0,"endpoint":1,"metadata":{"readable":true,"min":0,"max":99,"valueChangeOptions":["transitionDuration"],"label":"Target value","secret":false,"writeable":true,"type":"number","stateful":true},"propertyName":"targetValue","commandClass":38,"property":"targetValue","commandClassName":"Multilevel Switch","value":0,"prevValue":15,"ts":1777675363277}]}
dev:532026-05-02 00:42:42.741debugoff()
dev:532026-05-02 00:42:40.010debugon()
