Shelly rgbw2 white
Hey guys!
I'm using Shelly rgbw2 switch for my white led strips and I happened to notice that the adjust level (+ or -) doesn't work. I'm really not an expert, but I tried device driver for rgb use and there level adjusting works through "Start level change" command and it works if my strip is on any color channel, not on white channel. If I use the "Shelly rgbw2 white" device driver there is no "Start level change" command available, so adjusting doesn't work. Can anyone help me with this issue? I'm not clever enough to rewrite or adjust device driver to implement "Start level change" command into it.
Thanks to anyone for help.
