Hi.
Problems with simple motion and RM rules with shelly RGBW.
Made a rule but the Shelly does not go on ( red color ).
I also turn on another light and it works.
The last log is when I turn on shelly rgb manually in dashboard and then it goes on.
No in RM and motion light app it does not execute. If i press the tile in dashboard it works and if i make a rule that if light kitchen is off Rehn turn om rgb red it works.. so strange.
I had a fibaro rgb in the same motion rule and it worked but i Wanted to change to Shelly. I just switches them in the rule and it didnt execute. I also tried ro make new rules with it..
hmm the logs say its using 191,0,0 as red which is kinda right. Does it change to any color? What version of the driver do you have? I just tested this here and it works with all colours.
