Shelly device turning off automatic
Hi, my shelly one device keeps turning off automatic after about a minute for some reason unknow to me, I've attached the logs which don't mean a lot to me but hopefully do you haha. any help would be very much appreciated.
Show events
Apps and devices
Boiler heating switch
dev:4872025-11-03 05:17:30.898 PM
info
response data: [id:0, output:false, source:HTTP_in, temperature:[tC:57.1, tF:134.7]]
dev:4872025-11-03 05:17:30.895 PM
info
response contentType: application/json
dev:4872025-11-03 05:17:30.893 PM
info
params: [uri:http://null:null@192.168.2.203/rpc/Switch.GetStatus?id=0]
dev:4872025-11-03 05:17:30.891 PM
info
Response: Connection : close
dev:4872025-11-03 05:17:30.889 PM
info
Response: Server : ShellyHTTP/1.0.0
dev:4872025-11-03 05:17:30.886 PM
info
Response: Content-Length : 82
dev:4872025-11-03 05:17:30.884 PM
info
Response: Content-Type : application/json
dev:4872025-11-03 05:17:30.855 PM
info
response data: [:]
dev:4872025-11-03 05:17:30.853 PM
info
dev:4872025-11-03 05:17:30.850 PM
info
params: [uri:http://null:null@192.168.2.203/rpc/Shelly.CheckForUpdate]
dev:4872025-11-03 05:17:30.848 PM
debug
dev:4872025-11-03 05:17:30.846 PM
debug
dev:4872025-11-03 05:17:30.844 PM
debug
Response: Content-Length : 2
dev:4872025-11-03 05:17:30.842 PM
debug
dev:4872025-11-03 05:17:30.262 PM
info
Check Device FW
dev:4872025-11-03 05:17:30.260 PM
info
response data: [cfg_rev:22, debug:[file_level:null, level:2, mqtt:[enable:false], udp:[addr:null], websocket:[enable:true]], device:[addon_type:null, discoverable:true, eco_mode:false, fw_id:20250924-062720/1.7.1-gd336f31, mac:FCB467B9D07C, name:Boiler], location:[lat:50.914200, lon:-1.388000, tz:Europe/London], rpc_udp:[dst_addr:null, listen_port:null], sntp:[server:time.cloudflare.com], ui_data:[:]]
dev:4872025-11-03 05:17:30.257 PM
info
dev:4872025-11-03 05:17:30.255 PM
info
params: [uri:http://null:null@192.168.2.203/rpc/Sys.GetConfig]
dev:4872025-11-03 05:17:30.253 PM
info
dev:4872025-11-03 05:17:30.251 PM
info
dev:4872025-11-03 05:17:30.249 PM
info
Response: Content-Length : 434
dev:4872025-11-03 05:17:30.247 PM
info
dev:4872025-11-03 05:17:30.219 PM
debug
Sys Status called
dev:4872025-11-03 05:17:30.217 PM
info
response data: [app:Plus1, auth_domain:null, auth_en:false, fw_id:20250924-062720/1.7.1-gd336f31, gen:2, id:shellyplus1-fcb467b9d07c, mac:FCB467B9D07C, model:SNSW-001X16EU, name:Boiler, slot:1, ver:1.7.1]
dev:4872025-11-03 05:17:30.214 PM
info
dev:4872025-11-03 05:17:30.212 PM
info
params: [uri:http://null:null@192.168.2.203/rpc/Shelly.GetDeviceInfo]
dev:4872025-11-03 05:17:30.210 PM
info
dev:4872025-11-03 05:17:30.208 PM
info
dev:4872025-11-03 05:17:30.206 PM
info
Response: Content-Length : 215
dev:4872025-11-03 05:17:30.204 PM
info
dev:4872025-11-03 05:17:30.162 PM
debug
Sys Status called
dev:4872025-11-03 05:17:30.160 PM
info
response data: [bssid:fa:92:bf:5a:d2:c7, rssi:-51, ssid:Smart home, sta_ip:192.168.2.203, status:got ip]
dev:4872025-11-03 05:17:30.157 PM
info
dev:4872025-11-03 05:17:30.155 PM
info
params: [uri:http://null:null@192.168.2.203/rpc/wifi.GetStatus]
dev:4872025-11-03 05:17:30.153 PM
info
dev:4872025-11-03 05:17:30.151 PM
info
dev:4872025-11-03 05:17:30.149 PM
info
Response: Content-Length : 103
dev:4872025-11-03 05:17:30.147 PM
info
dev:4872025-11-03 05:17:30.116 PM
debug
WiFi Status called
dev:4872025-11-03 05:17:30.113 PM
debug
Shelly Refresh called
dev:4872025-11-03 05:17:28.097 PM
debug
dev:4872025-11-03 05:17:28.095 PM
debug
dev:4872025-11-03 05:17:28.093 PM
debug
Response: Content-Length : 15
dev:4872025-11-03 05:17:28.091 PM
debug
dev:4872025-11-03 05:17:28.029 PM
info
Calling /rpc/Switch.Set?id=0&on=false
dev:4872025-11-03 05:17:28.027 PM
debug
Executing switch.off
dev:4872025-11-03 05:16:31.452 PM
info
response data: [id:0, output:true, source:HTTP_in, temperature:[tC:56.5, tF:133.8]]
dev:4872025-11-03 05:16:31.448 PM
info
dev:4872025-11-03 05:16:31.440 PM
info
dev:4872025-11-03 05:16:31.436 PM
info
dev:4872025-11-03 05:16:31.433 PM
info
dev:4872025-11-03 05:16:31.429 PM
info
Response: Content-Length : 81
dev:4872025-11-03 05:16:31.425 PM
info
dev:4872025-11-03 05:16:31.390 PM
info
response data: [:]
dev:4872025-11-03 05:16:31.386 PM
info
dev:4872025-11-03 05:16:31.382 PM
info
dev:4872025-11-03 05:16:31.378 PM
debug
dev:4872025-11-03 05:16:31.375 PM
debug
dev:4872025-11-03 05:16:31.372 PM
debug
dev:4872025-11-03 05:16:31.368 PM
debug
dev:4872025-11-03 05:16:30.814 PM
info
Check Device FW
dev:4872025-11-03 05:16:30.812 PM
info
dev:4872025-11-03 05:16:30.809 PM
info
dev:4872025-11-03 05:16:30.806 PM
info
dev:4872025-11-03 05:16:30.804 PM
info
dev:4872025-11-03 05:16:30.802 PM
info
dev:4872025-11-03 05:16:30.800 PM
info
dev:4872025-11-03 05:16:30.798 PM
info
dev:4872025-11-03 05:16:30.763 PM
debug
Sys Status called
dev:4872025-11-03 05:16:30.760 PM
info
dev:4872025-11-03 05:16:30.758 PM
info
dev:4872025-11-03 05:16:30.756 PM
info
dev:4872025-11-03 05:16:30.754 PM
info
dev:4872025-11-03 05:16:30.752 PM
info
dev:4872025-11-03 05:16:30.749 PM
info
dev:4872025-11-03 05:16:30.747 PM
info
dev:4872025-11-03 05:16:30.689 PM
debug
Sys Status called
dev:4872025-11-03 05:16:30.687 PM
info
response data: [bssid:fa:92:bf:5a:d2:c7, rssi:-49, ssid:Smart home, sta_ip:192.168.2.203, status:got ip]
dev:4872025-11-03 05:16:30.684 PM
info
dev:4872025-11-03 05:16:30.682 PM
info
dev:4872025-11-03 05:16:30.680 PM
info
dev:4872025-11-03 05:16:30.678 PM
info
dev:4872025-11-03 05:16:30.674 PM
info
dev:4872025-11-03 05:16:30.668 PM
info
dev:4872025-11-03 05:16:30.607 PM
debug
WiFi Status called
dev:4872025-11-03 05:16:30.603 PM
debug
dev:4872025-11-03 05:16:28.585 PM
debug
dev:4872025-11-03 05:16:28.582 PM
debug
dev:4872025-11-03 05:16:28.580 PM
debug
Response: Content-Length : 16
dev:4872025-11-03 05:16:28.578 PM
debug
dev:4872025-11-03 05:16:28.544 PM
info
Calling /rpc/Switch.Set?id=0&on=true
dev:4872025-11-03 05:16:28.542 PM
debug
Executing switch.on
dev:4872025-11-03 05:16:28.072 PM
debug
dev:4872025-11-03 05:16:28.070 PM
debug
dev:4872025-11-03 05:16:28.068 PM
debug
dev:4872025-11-03 05:16:28.066 PM
debug
dev:4872025-11-03 05:16:28.040 PM
info
dev:4872025-11-03 05:16:28.037 PM
debug
This is the logs from the shelly device
Connected.
17:26:33
shelly_debug.cpp:236 Streaming logs to 192.168.4.202:54940
17:26:35
wifi I (36746681) wifi:[ADDBA]RX DELBA, reason:39, delete tid:0, initiator:0(recipient)
17:26:49
wifi I (36761721) wifi:[ADDBA]RX DELBA, reason:39, delete tid:0, initiator:0(recipient)
17:27:04
shos_rpc_inst.c:243 Switch.Set [1906300867@] via HTTP_in GET 192.168.2.200:59132
17:27:05
shelly_notification:164 Status change of switch:0: {"output":true,"source":"HTTP_in"}
17:27:05
shos_rpc_inst.c:243 wifi.GetStatus [886334622@] via HTTP_in GET 192.168.2.200:59134
17:27:07
shos_rpc_inst.c:243 Shelly.GetDeviceInfo [371940841@] via HTTP_in GET 192.168.2.200:59136
17:27:07
shos_rpc_inst.c:243 Sys.GetConfig [1906617088@] via HTTP_in GET 192.168.2.200:59138
17:27:07
shos_rpc_inst.c:243 Shelly.CheckForUpdate [270281778@] via HTTP_in GET 192.168.2.200:59140
17:27:07
shelly_update.cpp:355 Checking for updates (1.7.1 20250924-062720/1.7.1-gd336f31 {"bl":16777983,"t":1762190827.319,"ut":36763756701,"hf":136972,"hmf":110980,"fs":393216,"fsf":131072,"pkw":0})
17:27:07
shos_http_client.cp:316 0x3ffe07ac: HTTPS GET https://updates.shelly.cloud/update/Plus1?src=rpc (CA shelly_cloud.pem,ca.pem)
17:27:07
shos_http_client.cp:656 0x3ffe07ac: Finished; bytes 227, code 200, redir 0/3, auth 0, status OK
17:27:07
shos_rpc_inst.c:243 Switch.GetStatus [1424521149@] via HTTP_in GET 192.168.2.200:59142
17:27:07
shos_rpc_inst.c:243 Switch.Set [964213393@] via HTTP_in GET 192.168.2.200:59144
17:27:27
shelly_notification:164 Status change of switch:0: {"output":false,"source":"HTTP_in"}
17:27:27
shos_rpc_inst.c:243 wifi.GetStatus [1393671824@] via HTTP_in GET 192.168.2.200:59146
17:27:29
shos_rpc_inst.c:243 Shelly.GetDeviceInfo [1189094242@] via HTTP_in GET 192.168.2.200:59148
17:27:29
shos_rpc_inst.c:243 Sys.GetConfig [400746560@] via HTTP_in GET 192.168.2.200:59150
17:27:29
shos_rpc_inst.c:243 Shelly.CheckForUpdate [1036352785@] via HTTP_in GET 192.168.2.200:59152
17:27:29
shelly_update.cpp:355 Checking for updates (1.7.1 20250924-062720/1.7.1-gd336f31 {"bl":16777983,"t":1762190849.767,"ut":36786205261,"hf":137068,"hmf":110980,"fs":393216,"fsf":131072,"pkw":0})
17:27:29
shos_http_client.cp:316 0x3ffdf1c0: HTTPS GET https://updates.shelly.cloud/update/Plus1?src=rpc (CA shelly_cloud.pem,ca.pem)
17:27:29
shos_http_client.cp:656 0x3ffdf1c0: Finished; bytes 227, code 200, redir 0/3, auth 0, status OK
17:27:30
shos_rpc_inst.c:243 Switch.GetStatus [1639733102@] via HTTP_in GET 192.168.2.200:59154
17:27:30
wifi I (36806841) wifi:[ADDBA]RX DELBA, reason:39, delete tid:0, initiator:0(recipient)
17:27:49
wifi I (36821881) wifi:[ADDBA]RX DELBA, reason:39, delete tid:0, initiator:0(recipient)
Those logs are really hard to read (screenshots or at least careful formatting are easier), but I don't think they'd be helpful. The first thing I'd check is the "Events" tab on the device detail page for this device. Don't actually look for events, just "commands," entries with "command" under the "Type" column. If you see one for "command-off," that would be an obvious clue and would show you what app did it. If you don't, presumably you'll still see an event for switch off, and in that case, it suggest something outside the hub did it -- otherwise you'd see a command. If it's Wi-Fi, check anything else that might be using it (manufacturer's own app? other direct integrations?), or for any device, look for on-device "auto-off"-type settings that could be doing this on their own.
Hi, bertabcd1234 thanks for the quick replay, so about the busy logs, they mean nothing to me so I just enabled every logging option available haha. I've sorted it now, I had disabled my Advanced vThermostat Manager but not the child device and for some reason because this device is for my heating and it was part of this rule it was constantly trying to turn the device off. Its all sorted now though. On a different note have you had any experience with the shelly H&T ?
Many thanks
Mike
It wasn't so much the amount of logs as the formatting. But glad you got it figured out! I am not familiar with the other device. If you are trying to troubleshoot a similar problem, the same steps are a good place to start, or look here: How to Troubleshoot Apps or Devices | Hubitat Documentation
