Driver is updated:
Changed component enumeration logic from total count to ID lists. Different addon modules now expected to be properly visible to the driver.
Changed internal naming for temperature sensors that are related to switches and/or dimmers. Those will be recreated after 'Configure' operation. This is needed to avoid id conflict between Shelly Plus 1/2 build-in sensors and add-on sensors.
For add-on module 'temperature' and 'input' components are expected to be supported.
| peripheral type | component type | support |
| ds18b20 | temperature | yes |
| dht22 | temperature, humidity | yes |
| digital_in | input | yes |
| analog_in | input | yes |
| voltmeter | voltmeter | needs new child device |
Needs testing.
