Hi @dmitry.rozovik, I have been using the built-in HE driver for my Shelly Dimmer 2's. Do you have a better driver available? I can't see one listed on your github page
Hello @rhodesda,
Unfortunately my driver/bundle has no support for Gen1 devices. My driver is relying on a functionality that is only present starting Gen2 devices.
Maybe thread main repository has something you could use. Like Shelly-Vintage that is also a dimmer device.
I keep getting the message about not being able to process the bundle.
Also downloaded the file and tried again. Same error.
A hub reboot didn't help.
A hub reboot and database rebuild didn't help.
I had an old Shelly driver manually installed before but I removed both the device and the driver.
Any suggestions?
Hello,
The only thing that comes to my mind is possibly a file name clash with some other/older driver file.
Just in case please try this link: https://bitbucket.org/ge4d/hubitat-code/raw/f5d03aa04c9069011141512a7732b22f97676738/Bundles/Bundle1.zip
@bertabcd1234 @bobbyD
Tagging to ask a question: Is it possible to improove error reporting for bundles? It's hard to guess what actually went wrong in such cases.
What version of HE are you on? If it keeps being a problem you could open up the zip file and import each source file manually.
C7 with 2.3.7.145.
File (link) in this post worked: Shelly Device Handlers for Hubitat - #540 by dmitry.rozovik
However, there was no 'success of import' message of any kind. It just sat there for about 5 minutes until I hit cancel on the import... It then refreshed the screen to show a the drivers were imported as a bundle.
There is no loggin whatsoever in the log files so agree with @dmitry.rozovik that troubleshooting is hard.
YES.. this one worked!
Also see: Shelly Device Handlers for Hubitat - #542 by user3491
Thanks Dmitry!
hmmm, did some tests, I think the update delay is not working well.
Settings and device are saved after the new driver, "Update health status in (S) if link failed" is 60 seconds. Health status stays online
Thanks for the report! I will investigate the case.
Driver is updated:
- Added new component support 'pm1' for 'mini PM' devices
- Other internal maintenace changes without significant impact on general behavior (no need to update driver for this one)
Driver is updated:
- Fixed health status check (needs real world testing)
it looks fine, thx
@dmitry.rozovik Thanks for your efforts to support Shelly devices! I've been trying out different drivers for the Shelly Plus 2PM in cover mode and your driver is working well. Having the child devices is making the most sense and enabling the behaviour I'm looking for.
I have a question about HomeKit integration related to this device. Is there anything you're aware of that may be missing to enable the 'cover' to operate properly with HomeKit? What I'm experiencing is the window shade button doesn't represent the right state (open/closed) and although I can initiate the cover moving to a mid-point by tapping the button and then sliding in HomeKit, the button immediately jumps back to open even though the physical cover moves to the requested position. I'm not sure where the problem is, but I'm starting here to track it down. The state in HE is correct while this is occurring.
In this case the cover child device is exposed to HomeKit:
Window Shade
Dining Room Shutter Relay cover 1 (in Dining Room)
Export as: Normal (0 = closed, 100 = open)
Required capabilities: Window Shade
I have no info on HomeKit integration. But I'll try to check if there is anything in the Window Shade child device that needs to be additionally configured (like operating modes list for thermostats)
P.S.: One thing that come to my mind right away is a scale factor: Could it be that HomeKit expects [0..1] range while device provides [0..100]? In this case anything more than 0 could be threated as 'open' state
One inconsistensy/error is present in the driver related to the window shade:
Driver sets windowShade attribute value directly from the device report. But device has state 'stopped' that should be mapped to 'partially open' as listed in the attribute enumeration.
Not sure if this one can be the cause. Will fix it shortly.
I'm new to the forum. I have 4 x Shelly 1's that work well with the HE system driver.
I've just added a Shelly Plus 1 and I noticed that no child device (switch) is created. I've read this thread which is great and downloaded the Switch Relay Driver 3.0.10. I can see new attributes in the parent device when it is polled, but alas no child device.
Can someone steer me in the right direction please?
I found a clue in the Shelly Technical Documentation. By running /rpc/shelly.getdeviceinfo, I get a JSON returned that contains:
"name": null,
"id": "shellyplus1-441793d6xxxx",
"mac": "441793D6xxxx",
"slot": 0,
"model": "SNSW-001X16EU",
"gen": 2,
"fw_id": "20231219-133950/1.1.0-g34b5d4f",
"ver": "1.1.0",
"app": "Plus1",
"auth_en": false,
"auth_domain": null
I note that the Shelly Switch Relay driver code doesn't contain a code for this model? Does that mean that this driver doesn't support Shelly Plus 1 and if so, is there another driver or resource that might help me?
Tim
The one that has version 3.0.10 is the driver for Gen 1 devices. I can't say if it will work with your Gen 2 device. Some Gen 2 devices have a bit of backward compatibility.
The driver in the PLUS subfolder should be a better choice (version 1.0.2).
All those drivers have no 'child device' functionality and operate as an instance-per-component. I.e. if for example you have dual channel device you'll need to install 2 device instances specifying channel id for each of them. In your specific case you have a single channel device, So you need only a single instance of the driver.
The one with child devices is a different driver from different repository, and it's referenced in the thread later.
Thanks for the detailed reply Dmitry - I'll take a look.
I have had success (simply turn on/off the relay) using the ShellyPlus Generic driver from Sebastian Yepes: https://raw.githubusercontent.com/syepes/Hubitat/master/Drivers/Shelly/ShellyPlus%20Generic.groovy
